CD 200 - I'm back...
Re: CD 200 UK/US build- carbon/kevlar tank and seat
How rigid is 1 layer of kevlar and carbon? Assuming that's all you've used.
not very rigid at all! i have used between 2 and 5 layers of glass all over. i thought 1 layer of glass and one of carbon kevlar would be rigid enough, but early on i realized its not. i then decided to get a yard of pure carbon cloth to add to the layup, which would have added a lot of stiffness, but unfortunately that was a bank holiday weekend, so nowhere was shipping until today (and i realized last friday). so i just added more glass becaause i had it lying around. carbon is stiffer than glass, but tends to absorb more resin (unless you vacuum bag) so the weight difference shuldnt be too bad.
I think my sense of heaviness is messed up because i am a keen ultralight backpacker, and weigh all my gear to the 10th of an ounce...but motorbikes are f'in heavy, especially an old commuter bike like the CD200!
still, i weighed the stock tank and seat, and i will weigh my versions, probably tonight, and add a couple of ounces for the seatpad, and let you know how much weight i am saving!
i do plan to weigh the bike at then end and compare it to the stock weight.
Adie
I was going to say! I've used 4 layers of GF woven mat & epoxy on my seat recently and that isn't that rigid.
I'd love to experiment with CF but due to costs I might experiment with skin&bones construction with CF tow.
cf tow is a good material, but how exactly are you planning to incorporate it?
I built a bamboo bicycle frame, with CF joints, and i used 6k tow for that, because i could wrap the joints easily, and the tow was easy to make conform to the complex shape of the joint. also, as you wound it on, the tightness forced all of the excess resin out of the layers below, giving a better resin content ration than could have been achieved with cloth.
but it seems the cloth would work much better for tanks etc. dealing with cutting the tow to length seems like such a pain! i was able to cut 50ft-ish lengths, wrap them around a dowel using a drill to turn the dowel, and then pass the dowel around the joint. that worked well. it ended up being about 2000ft of hand wrapped carbon in the end...very time consuming.
i think you could make a tank and seat with 2 yards of cf cloth and yard or two of glass (for the outside surface, that way you dont compromise the strength of your cf by sanding through it when you do the final shaping.
who knows what the actual weight savings are tho.
I wasn't thinking of using tow for fairing etc. More for structural parts like on the Briteen V1000: Alu mountings and tow wound between them.
adie.mitchell said:
I built a bamboo bicycle frame, ...
:-0! Please post that up somewhere... Would love to see that...
i took it on a two month bike tour of france and spain...here was my blog.
bamboobiketour.wordpress.com
here is the bit about the bike itself.
http://bamboobiketour.wordpress.com/category/bikes/
enjoy
WOW, that is awesome! :-) Thanks for sharing.
Awesome creativity and skill! I'll watch this one too.
For the tank, one idea to show off the kevlar would be to leave an exposed stripe. One of the Ducati 1198 models with an aluminum tank had an exposed stripe of aluminum.
Sweet! I hope it does. It was a Ducati idea. I just passed it along.
My Felt F5 carbon fiber road bike has areas of exposed CF too.
Hey, thanks for the support guys.
unfortunately, today is my last day before leaving for college and has been taken up with packing etc. it is really disappointing to have to leave the bike now for 9 months, just as i started to make forward progress! its probably the opposite to most people, who really get into their builds during the long winter evenings!
I will be leaving this project for the year, but there is of course another one to distract me from school work. it will be a custom bike...of the pedaled variety. the exciting bit is that i have befriended the college machinist, who normally builds telescope mounts for the physics dept, but runs an awesome shop with 3 or 4 mills, lathes, cnc machines, laser cutters etc etc, so hopefully this will be a unique bicycle. im thinking custom machined dropouts, that kinda thing!
i will post some links when i get started.
Adie
The "stripe" down the tank was in fact transparent and used as a fuel gauge.
Hey, good luck with College, and enjoy making the bicycle.
I remember that bike. But the tank I was referring to was an aluminum tank, not transparent. The 2011 1198SP:
Can't wait to see those machined drop-outs! Add some aluminum chain tensioners while you're at the milling machine!
chain tensioners? lol, im going with an eccentric bottom bracket. road/touring geometry, but room for fat (fat!) tires, and disc brakes...gonna be wild!
also, i really like the fuel gauge stripe, i have seen that on a couple of bikes, but the carbon/kevlar isnt see through :(
Going waayyy off topic now! I guess you upped me on that one! :o Going motorcycle tech on a bicycle! Nice! There are a lot of crossing of technology between motorcycle and bicycle building nowadays. Now, how about power measuring cranks, electronic shifting & wireless speed sensors? Brakes? If you're going fixed gear, toss them out! ;D Are you going mechanical or hydraulic? Maybe, you can apply some eccentrics to other parts (seat post clamp, adjustable frame geometry, etc)? Mill your own quick releases and levers and ... ooohh! Getting the idea engine really moving now...
If you still wanted a visual fuel gauge, you can also use the old school external transparent fuel line. Add a couple of 90 degree nipples top and bottom, then add a vertical fuel line. Does the same thing.
Good luck with school. I'm sure there a lot of roadies here that will be interested. Anything on two wheels gets me going.
