cd/cb 175 lighting
supercafe
Coast to Coast
whats up racers.
need help, in the lighting side of things.
on my build i am keeping the stock signals and what to use differant
rear brake light. either l.e.d. or a regular light. now my bike runs a
6v sys and i what to know if i can run these lights or do i have to up
grade my sys to 12v. and if i don't what will most likely happen?????
thanks.
later.
supercafe said:
whats up racers.
thanks.
later.
I would suggest the easiest option which is to use a standard bulb tail light you like and put in a 6V double filament bulb. LEDs would require you to up the system to 12V, which might effect your ignition system, too much hassle in my opinion, 6V systems work fine as long as your running with a battery and not just a magneto - where you get dimming lights on idle. I am building a CB125 Cafe for my wife and I changed the signals to smaller after market ones, just putting in 6V bulbs. I am changing my tail light also with the same method. Thats my 2 cents, keep the change. -MBS
whats up.
thanks for your input. i think, the same as you that its to much of a hassel.
i think i'll just get 6v bulbs with a lense i like.
thanks man.
hows the 175 coming??????
thanks
later.
if you mean my CB125, well its slow going, my shop is freezing which makes it hard to get anything done. I have installed an over heard quartz heater, but it takes the cill out at best, I wouldn't call it warm. So I have done one or two minor bits to it in the last couple months. Put on some clubmans and I'm learning that paint stripper and cold are not friends. It says on the can, for best results use between 65F and 85F degrees, I thought 30 might be slow but doable. lets just say it been hours (30 mins is the norm at 65 degrees) and the paint is still on the tank. Thought it was worth a shot, worst case I clean it off with mineral spirits and try again in the spring.
thats tough, not being able to get any work done and having to wait till spring.
i bet u'd be happy to work on ur CB125 where i live.. its summer all year long...
haha.
im not an expert on electricals and batteries and wat not. so i guess that means if im running a 6v system, i cant just change my lights to any ol' bulb? i have to get 6v bulbs? so if i wanna switch to a 12v, what would it take? i mean, what do i have to do? i suck at all these electrical stuff.
hey do u guys have pics of ur bikes?
cool. do you have pics of that ride???
where are you located????
i'm in brockville and luckly have a heated garage to work in, but is nice and cold here.
thanks for the earlier response.
later.
Yes it does suck. I installed an over head quartz heater this past weekend. Works well but you have to stand right under it in this cold to get any warmth. As far as a 12V conversion, you might have to replace your rectifier, points, coil and charging system to support 12V - basically replace most of the expensive components in the wire harness - if you can find them. I am not that ambitious. As I said I haven't made much progress but I'll post some pics as soon as I can. In fact I will start a dedicated thread and let you all know. -MBS
just go buy a cool looking led trailer light and swap out the current limiting resistor inside for one that will make it work at 6v or build your own light for 6v. LEDs consume much less current then any bulb (good for old small bikes with a weak electrical system) and they all operate well below 6v. The current limiting resistor 'burns off' the extra juice so they can run off higher voltages. since most cars and bikes run off 12v that's what they spec the resistor for, but the lights I put on my bike the resistor is clearly visible and could be swaped out for another one making it possible to run off of any voltage.
thats a cool idea. never knew that could work.
that'd be cheaper than converting to 12v.
i guess i'll take a look at the resistors and see if i can swap em.
like i said, not very good with wires.
haha.
but thanks anyway.
thanks guys, i did'nt know that either.
i'll get some at work tonight and see if it could be replaced.
so basically have to re/re the resistor, but with what. where do you get
the 6v resistor?????
thanks for the input.
later.
It's not like there is a 12v or 6v resistor. the value and size of the resistor has to be calculated based on the required voltage drop and how much current needs to pass through the light. If you post a close up photo of the light so I can see how many LEDs there are and the stripes on the resistor I can tell you what resistor to use for that light.
hello.
i just figured out the lights i am going to use.
transport clearance light. a singal led light, using two.
i hooked them up and they work fine, also hooked up
a clearance and brake light, light. and it worked fine.
but is two big for the seat i'm using.
it has at least 18-20 leds in the light. with no booster used.
my bike is a 6v sys, and they worked fine..
i will post the lights for you steve and hope you could tell me
what resistor to use.
thanks.
later.
yeah yeah, do post pics soon. i wanna see.
cos i gotta tell u, im quite lost here.
haha. im more of a computer geek than anything else.
supercafe said:
hello.
thanks.
later.
What voltage is the lamp rated for? it should say somewhere on it. if it's rated for 12v then it prob lights at 6v but nowhere near it's full brightness.
Yeah this should be interesting, I am looking forward to the pics also. I used to be able to read resisters and know what the different bands represented, but I haven't thought about it in years, and I'm not sure I remember much of it at this point. It was handy back in the day when you used to fix computer boards circuits, but when was the last time anyone actually repaired a board? You can't even see the resisters on boards these days. I assume with the lights we are talking much simpler technology though.
hello.
just picked my lights, went back on my original idea.
so hopfully tomorrow i can get a pic up for ya's.
thanks
later
