I just got a cb450 front end to put on my cl450. I wanted to use clip-ons and the cl450 front end had fork tubes that are tapered at the top so they had to go. my question is how do I center the wheel in the new forks? I am trying to use my 19 inch drum front wheel on the cb450 forks that are made for disk brakes, the new forks are about a 1/2 inch wider and the drum brake axle is too short, also there is about a 1/4 inch gap on each side of the wheel. I think the cb450 axle must be about a half inch longer and should solve the axle issue but I am not sure what to do about the gaps between the wheel and fork. Can I use washers or do I need spacers? Can I but spacers somewhere or do I need to have them made?
Thanks for the help!
Here are a couple picture to show what I am working with
