Chain Adjuster Question
ksprzk
Active Member
Hello!
Haven't been on here in a minute. Took some time off from the CL360 project but i'm back! I'm beginning to rebuild everything and i'm guessing i'm going to have a bunch of questions. Here's my first.
Went to tighten the back wheel last night. Seems as if the hole that the bolt goes into is stripped or isn't threaded.
This might seem like a dumb question but oh well, Is the hole that the bolt goes into threaded?
Second- is there a nut on the inside of piece as well or just on the outside like this picture shows. I'm guessing if the hole is threaded there isn't a nut but let me know.
hole should be threaded. the nut is a lock nut.
Method is thus:
Loosen axle
loosen lock nuts
tighten bolts evenly on both sides until chain is at desired tension
while holding the bolts in place, tighten lock nuts to keep bolts at current position
Retighten axle
