Chain length issues HELP!
MILLENNIUM FALCON
Over 1,000 Posts
DTT BOTM WINNER
I feel kinda dumb.......................I am trying to fit my chain on my latest project but I cant figure out what to do, here is my dilemma; With my chain adjusters all the way back (axle all the way back in the swing arm) the chain is to loose. So I need to remove a link. no biggie, but I have to remove two links in order to be able to get the master link on. Once I do this the chain is now to tight. Then I have to put the rear wheel so far forward in the swing arm that my tire hits the swing arm before the chain gets the desired slack. What I need is to be able to remove just one link. This was hard to describe so please forgive me if this sounds confusing. Thanks.
Do you have an oversized tyre on the back? I can't imagine any other reason why you should have this problem.
If it's the chain on the enduro it should be Long with more slack than you think you'd want because of the amount of rear wheel travel....But in any case i think they sell half links.... Are you using a chain breaker tool?
Take your old chain and lay it side by side with the new chain and match them link for link Or count the number of links on the old one and use the same number of links on the new. If your old chain wasn't an issue, the new shouldn't be either.
Or was this a custom fitment and there is no old chain?
We really need pics. Something is not right if you can't remove a link of chain within the adjustment zone of the tensioners.
JustinLonghorn said:
You should consider running a chain tensioner.
Where can you find these? Only pull up bicycle ones on my searches. Would be good to have the ability to weld it to the swingarm.
This is a completely custom build. frame/engine/axle everything. I don't have an old chain. I am quite familiar with the amount of slack needed for longer travel suspension, but this is a unique circumstance. I think that part on my problem is that I had to bore out my swing arm to fit the larger axles and now I have less range of adjustment. One you remove a "link" the amount you have to remove to be able to reinstall the master link make quite a bit of difference in chain slack. I found half link master links for sale so I might go that route. I could also change a tooth or two on the sprocket to help the situation. Thanks for the help guys. i might try to get some pictures later.
Monster Craftsman sells a variety of chain tensioners - it's their speciality
www.monstercraftsman.com
