Chain pitch question
1fasgsxr
Over 1,000 Posts
I have found that the stock chain pitch for a 350 F is .625 in inches. I am guessing that is for a 530 chain?? What I would like to know is what is the 520 chain in inches....
Same. 520, 525, and 530 are all 5/8"
As you may have now deduced, the first digit is the pitch in 1/8ths of an inch. 428 is 4/8 (1/2"), 520 etc are all 5/8 and 630 are 6/8, better known as 3/4 inch.
The second two digits relate to the width 520 is narrow, 525 is wider and 530 is widest 520 is 1/4" wide between the plates or the roller length, 525 is 5/16 and 530 is 3/8 ie 80ths of an inch.
All chains are not created equal however. Some chains are more equal that others. There are different pin diameters and different side plat thicknesses and materials that contribute to the wear index and strength of the chain.
Cam chains are typically 219, small hondas often use 428 chain and an RS125 uses 415 IIRC.
Interesting that many Karts run a 219 drive chain. Yes they use the same chain to drive them that Honda uses to drive a cam.
