Chain / Sprocket question
Crash
Crashing is a way of life
OK, I replaced my stock 33 tooth rear sproket with a new 30 tooth spocket. Original chain on the bike (a bit stretched) flaps in the wind. It is a 520 106 link O-ring chain. Should I replace with a 106 link, or go do to a 104 link? Difference in diameter is about 1/2 inch between the two sprockets.
I would use the size that put my rear wheel axle closest to the center of the adjustment gap. That's the design point for the wheelbase.
Buy a decent length chain and shorten it to the length you need. I bought a 120 link 520 x-ring chrome EK MVXZ chain from Bikebandit for US$75 and I'll likely be removing 10+ links.
Unless you know for sure, I wouldn't try to buy exactly the length you're going to end up using.
