kempbartlett
I recently purchased a 1973 Honda CB350 and have just purchased 16 teeth front sprocket and 36 teeth rear sprockets and am now in the market for a new chain. However this has turned out to be more difficult then i had expected. Through some research i have seen some members here and on other forums complain about how "o-ring chains" do not fit on the 1971 CL 350 because of clearance issues. So question number one is, is this a problem for all CB's/CL's or just the '71 CL? After reading that i got a little spooked and stared looking for OE spec chains for a CB350 and was able to find one for super cheap on DimeCityCycles steel on steel (original) for like $30 or something. At first this sounded great and seemed like the obvious choice. Upon telling one of my other four buddies building bikes this summer i was told that buying that chain was a terrible idea and i should really only be getting a D.I.D x ring chain ( think that's what it's called) which cost $143... obviously a LOT more than $30. So question number two is , what makes a D.I.D "x ring" chain better than an O-ring chain or an OE spec steel on steel chain to make it worth the extra $100? thirdly if this clearance issue with the o-ring chains is an issue for all CL's/CB's will the D.I.D x ring chain have clearance issues? As far as i have been able to find out 530 is the correct standard chain width and 96 links for the standard 16F 36R sprocket set up, is that correct? I gave a call to Sprocketspecialist and they said they had a chain that would work for me , but i have delayed calling them back til i determined really what chain i need! Thanks for all the help and sorry its a loaded question!
Kemp
Kemp
