Changing braided line bolts
smudge1990
Hello all,
Currently got Kawasaki gt550 master cylinder with 14mm braided hoses that is broken.
Have a CB600 master cylinder that is marked as 1/2 (12.7mm).
What do I need to change down the 14mm bolts at the top? What's the name of those bolts? Do they just unscrew and are therefore interchangable?
Hope you lot understand what I mean!
Thanks in advance.
The size in mm refers to the bore size of the piston in the master cylinder.
Going to a smaller master will change the way your brakes behave.
As for the bolt, it's called a banjo bolt and yes it just unscrews
Also make sure you replace those old washers with fresh copper or aluminum crush washers for a good seal at the recommended torque specs. If you don't it will likely leak... I've used copper and aluminum before and both work well and I use aluminum most of the time because of price... You should have one washer on each side of each banjo bolt on the side near the hose.
