tyeddingston
Howdy,
Getting real close on my CB550 build and I've got one issue that I can't seem to get to the bottom of. I cannot for the life of me get the charging system working.
I've completely rewired the bike, loosely following the hondachopper diagram and am using a Rick's Motorsports Reg/Rec combo unit.
I have:
(From Alternator)
Yellow > Rectifier
Yellow > Rectifier
Yellow > Rectifier
Green > Frame Ground
White > Regulator
From Reg/rec:
Yellow > Alternator
Yellow > Alternator
Yellow > Alternator
Red > Solenoid
White > Alternator
Black > Ignition
Does any of this seem incorrect? To the best of my knowledge, this is the correct wiring setup, however I'm still not charging, and I was before the rewire. So, I've got to believe this is mechanic error.
I've heard of reg/rec units being finicky about how they are mounted, and have tried mine both rubber mounted and direct to the steel wiring box that is direct welded to the frame.
Any ideas? Hoping to be riding this mad dog around soon.
Cheers
Ty
I have:
(From Alternator)
Yellow > Rectifier
Yellow > Rectifier
Yellow > Rectifier
White > Regulator
From Reg/rec:
Yellow > Alternator
Yellow > Alternator
Yellow > Alternator
Red > Solenoid
White > Alternator
Black > Ignition
Cheers
Ty
