Charging issues, CB550
tyeddingston
Howdy,
Getting real close on my CB550 build and I've got one issue that I can't seem to get to the bottom of. I cannot for the life of me get the charging system working.
I've completely rewired the bike, loosely following the hondachopper diagram and am using a Rick's Motorsports Reg/Rec combo unit.
I have:
(From Alternator)
Yellow > Rectifier
Yellow > Rectifier
Yellow > Rectifier
Green > Frame Ground
White > Regulator
From Reg/rec:
Yellow > Alternator
Yellow > Alternator
Yellow > Alternator
Red > Solenoid
White > Alternator
Black > Ignition
Does any of this seem incorrect? To the best of my knowledge, this is the correct wiring setup, however I'm still not charging, and I was before the rewire. So, I've got to believe this is mechanic error.
I've heard of reg/rec units being finicky about how they are mounted, and have tried mine both rubber mounted and direct to the steel wiring box that is direct welded to the frame.
Any ideas? Hoping to be riding this mad dog around soon.
Cheers
Ty
That's not the correct R/R for your bike.
A CB550 also requires a white and a second green wire in addition to those you mention above.
Hopefully I've just done a poor job explaining.
The reg/rec I got from Rick's has:
Three yellows, a red, and a green grouped together, as well as a white, black, and a green (what I presumed to be the regulator portion of the unit).
Edited original post to reflect more accurately.
Sorry... I misread your original post. Everything sounds correct, so lets test your alternator.
Measure resistance between all possible combinations of the three yellow wires, and then between the white and green regulator wires and let us know your results (also, make sure the green from the alternator is going to the green in the R/R and not to the frame).
I won't be able to be back at the garage until Friday. BUT... I currently have the green wire from the alternator grounded to the frame. Which green from the reg/rec should it be connected to? I'd guess the one grouped with the rectifier wires?
Is the Red wire to the solenoid on the same terminal as the Battery 12V wire? Red is 12V out from the regulator to the battery.
Green is ground, all green wires need a good ground.
White wire goes to Alternator field through the slip rings....When running, you should see some volts on that wire.
Black is usually sense wire, Reads 12V for reference, also supplies power to the internal circuitry.
The 3 yellows are AC (Three phase) output from the alternator....yellow to yellow.
If you are hooked up that way, it should work. I would, for good measure, make sure the case of the R/R is grounded too, either by the mounting bolt, or put a wire from the mounting bolt to a known good ground....
If you are hooked up this way, it should work....
From the reading, I would guess that the red wire to the solenoid may be on the wrong terminal....Without being hooked to the battery, it wouldn't charge.
Did Rick's give you any sort of schematic? If not, shame on them.....
mydlyfkryzis,
Red wire was indeed on the wrong terminal of the solenoid. Still no charging. All of my other connections are as you stated...
I'm stumped.
Sonreir: Which green in the R/R should my green from the alternator go to? The one in the rectifier bunch, or the individual regulator green? I've got conflicting info on this.
They're both connected internally, so it doesn't technically matter. There is usually a thinner gauge one, though, and that's the one that's designed to go to the alternator.
Copy that. Well, I've tried all possible combinations that make sense to try. Running out of ideas.
Does the location of my main battery ground matter? I've tried so far in two locations on the bike: 1) Under a bolt beneath the seat (Paint removed with dremel), and 2) The original location on the right side with the engine mount.
Brushes and ring commutators are often the problem with charging. If the regulator can't put voltage on the rotor, no output ac. Have you checked for ac output???
Sent from planet Earth using mysterious electronic devices and Tapatalk
To add, the green and white wires on the alternator are voltage supply from the regulator. they go to 2 brushes that ride on 2 copper rings. The regulator varies voltage on those 2 wires to vary the strength of the rotating magnetic field (ROTOR). The rings can get chewed up, the brushes worn. The three yellow are AC output. If you have no AC out, then the rotor may be the issue, which can be brushes, ring communtator, or a bad coil in the Rotor....
Sonreir is right, check these with a multimeter. Open or shorted is NG.
Sonrier/mydlyfkryzis:
I have checked continuity on the alternator as well as for AC output, both came up good.
Out of frustration and looking for answers I decided to hook up my old rectifier and regulator and got some interesting results. With the OEM parts, I am now overcharging (took it up to 15.5V then backed off for fear of damaging anything). The old regulator seems to be doing no good, but the rectifier is functioning. Which brings me to my next question: how difficult is it to fry a regulator, and is it in the realm of possibility that I have somehow fried the R/R unit? Frankly I am not sure if I was overcharging before rewiring the bike, but I doubt it. Was never popping fuses or anything.
