Charging system. Im stumped.....
AzHonda
Coast to Coast
I have a 73 cl350. I have put in a new used stator ( its putting out 20+ vac), new used regulator and a new rectifier. Im still not getting any increase in volts at the battery. Connections are all good as well.
Any ideas?
Yes. Make SURE the battery is good out of the bike.
Then you can test the reg and rec.
20+VAC out of stator is good. What is the voltage after the rectifier? (should be roughly the same voltage but now DC rather than AC)
Now after regulator (at battery) should be no more than about 14-15V DC. (13-14 is preferred)
Other than the wires themselves and connectors, that's the entire system. It's got to be in there somewhere!
Also, check all of your grounds very carefully including the strap between the engine cases and the frame/negative battery terminal...
Good luck!
Your not going to believe this shit!
I have been racking my brain on this for over two weeks. Even started another thread earlier on, went through two stators. Welp....just after I started this thread, I pulled up the wiring diagram (again) of my bike and started looking at the how the white wire coming off the stator runs and connects to the yellow wire inside my headlight bucket. I started thinking..........those wires aren't hooked up are they?
Sum bitch! Fixed.
Missed out on 2-3 weeks of riding because of this simple fix. Live and learn. Also, thanks for the help guys as well as on the other thread. I did learn some things that I didn't know before.
ADC- I had searched and found a link you had posted off of your website about a week ago that taught me some things. It helped rule out some issues.
My bike was charging below spec.
I went through and checked everything and it seemed to all check out. I cleaned all the connections, replaced the regulator, fuses. Nothing seemed to fix the issue. So ran new wires from the regulator to the battery. 12 gauge wire with a 25 amp fuse on the positive line. Boom, a steady 14.5 volts.
