AlphaDogChoppers
Science is true whether you believe in it or not.
Most of us already know he is a Virago Victim. <G>
AlphaDogChoppers said:I am going to respond to this one first.
14.6V is way too high for an AGM battery. 14.2V is ideal. Any higher voltage than that, and the battery will vent and dry out. They have very little electrolyte in them, so they can't afford to lose any through venting, and they will have very short life.
The charging systems in most of the older bikes is designed for flooded cell batteries. They are much more tolerant of overcharging, because they have a lot more electrolyte, and you can add water to replace what is lost.
Rich Ard said:Sounds reasonable - I do not see a drop across the battery under load, and am getting good voltage at the coils, but it surely can't hurt.
hillsy said:I suppose someone should ask what bike we're talking about here.
AlphaDogChoppers said:I don't think you have a charging system problem.
First of all, if you take a voltage reading immediately after starting, it will be a little on the low side because the battery is sucking up electrons to replace the ones you pulled out to start the engine. The charging system on these bikes is barely adequate, so the extra load of charging the battery for the first few minutes will pull the voltage down a bit.
I was working on a Virago recently, and had a baffling problem with the starter only triggering intermittently. I spent a lot of hours going over everything. I was getting voltage from the wire that supplies power to the [new] solenoid. The wire that grounded the circuit through the starter butting was working fine. If I jumped power to the solenoid lead that should be hot when the key is on, it would work when I hit the button. WTF?
I made a test light from a turn signal bulb. I put it on the hot wire leading to the solenoid, and as soon as I applied the load, the voltage dropped to a tenth of a volt. AH HA!
After considerable time pulling apart, cleaning & greasing connections in the headlight bucket, I found my way to the fusebox. The culprit was a broken fuse holder. It looked OK, but two blades of one of the fuse holders were fatigued, and as soon as I touched them, they fell off. The fuse was just hanging in place, barely touching its holder. Enough that I could read a voltage, but not a good enough contact to carry any load.
I think you have a poor connection somewhere. If you still have the fusebox, start looking there.
stroker crazy said:Ask Brad about fixing batteries!
Crazy
SONICJK said:So when you hit the starter theres no voltage drop?
DeanJ said:Good info thanks! by the way, the max charging voltage on the AGM I had fail is 15.4v per the specs ( what it did NOT state is that this max is at only 40 degrees f ...... and the max voltage at 80f is 14.4v ... assholes )
Sealed AGM batteries do not "vent and dry out"... what happens is they gas internally and fail - the oxygen leaves the water molocules at the negative plates and hydrogen is released at the positive plates.. when over charging occurs, oxygen can not recombine with the hydrogen to return to the h20 state within the gel and yes, you can not add more gel...
Someone needs to make a regulator for old bikes that work with modern AGM batteries... it would have a variable voltage output based ambient temperature and the lower max v.
TripleKing said:Having a similar problem on my 71 CB450. Tried two new batteries and checked every connection I could find. Stator puts out power, none get to the battery.
JohnGoFast said:Great to hear. I would expect the coils to be hotter than you'd be willing to close your hands on. Were they not before this?
This thread was a great read BTW.
bradj said:If my wife was on one of those see and say toys it would be like "the wife says WHEN YOU GONNA STOP FUCKING WITH THAT OLD JUNK MOTORCYCLES, IT ALL YOU EVER DO....AND IT JUST GOING TO BREAK AGAIN, DUMBASS I THOUGHT YOU COULD FIX STUFF" you may have to pull the string twice to get it all out
TripleKing said:Rich Ard, every connection I could find was cleaned. This is the last thing holding up the project and I am baffled.
