Charging upgrade for CB450?
Garage_guy_chris
soon enough im going to be totally rebuilding the charging and whole electrical system on the CB450 i definately want to dump the old selenium rectifier and hopefully the voltage rectifier too, I have seen upgraded rectifiers all over the place but nothing to replace the voltage regulator,
what i have in mind is to use a f4i regulator/rectifier but im not sure it will work? I lack the knowledge to understand the A/C side of things. and the two manuals don't quite say enough to bridge the gap
the f4i regulator has 5 connections 3 yellow, for the A/C then red and green for the DC pos and neg
the CB charging coil has a yellow a white and a pink, my only concern is that the coils aren't equal in size or capacity but it looks like i can just wire the yellow white and pink, to the three yellows on the f4i regulator??? then use the output red and greem into the electrical system?
Just wire the F4I one in if you already have it.
Its probably got 5 or 6 wires?
3 to alternator, one to battery (Red) one to ground (Green) one to a switched live (probably black)
If it doesn't have green wire, make sure its grounded on mounting bolts
PJ
