dewjantim
duc in the park.....
When rebuilding your top-end use the perfect seal gapless rings. The top or second ring on these ring sets are stepped and overlap at the stepped part. There is no ring gap. This will reduce blow by, increase compression during use, reduce carbon build-up in the combustion chamber and make your engine run better. Also while it is apart, polish the piston surface to a mirror like shine, do the same to the combustion chamber, use 80 grit stones to clean up the surface of the intake chamber, and polish the exhaust chamber. You can also match the intake to your intake ports and sometimes to the carb. Take a holesaw with an extension and drill through the center of your muffler, it will be a little louder but allow the engine to breathe better. Don't forget to play around with the jets a little for optimum performance. When replacing the head gasket, try to get a thinner one to increase your compression. When doing this be sure and check for valve to piston clearance. When replacing your airfilter use the K&N stock filter replacement. All these little tips will cost you little or nothing except a bit of your time. They are tried and true hot rod secrets used since the internal combustion engine was first produced. Don't know why my bike will out run yours.........it is stock......sorta
. Later, Dewey 8).
