brian weir
AHA!
had problems galore getting right side to idle . either 700 rpm to dead,
or 2000 rpm plus.
checked the original 40 year old intake rubbers. bought new ones. no air leak,
then spotted the choke link across the carbs can cause one of the chokes to be slghtly on, depending on vibration, rubber angle etc causing little movement of choke comector spring clip. lleft side carb was ttally tunable, right was giving either 2000 rpm or 700 then down to dead. big hint was fluffy plug right side.
warmed bike, then wired chokes totally open and tried, no more flutter ! HA! tunable bike!
i have had great trouble finding this problem on my own but got it now.
does it idle ok on one side? big hint there on choke flutter if no air leak an all else ok.
that is probbably why they put the bar across the 500t carbs it think, i will likely do that to mine.
regards,
Brian
regards,
Brian
