Choosing relays
mysta2
Over 1,000 Posts
DTT BOTM WINNER
I'm looking for a couple of headlight relays and probably a ignition switch relay so that I can use a small toggle for that.
Having looked through Waytek Wire for days. I'm more confused than ever. They have mini relays and micro relays. Since I'd like to stuff everything into the smallest space possible, the micro relays sound pretty cool.
These (one for high beam, one for low, one for ignition, and one for start):
http://www.waytekwire.com/datasheet/Picker-PC782-Relays.pdf
Wired to this switch, one for high beam, one for ignition, and a momentary for start
http://www.waytekwire.com/datasheet/44251.pdf
I just need help to sort through all the requirements and specs.
Depending on the wattage of your headlight, you're going to want something rated at 10A. Most other features are just icing on the cake. If you want one relay to control the high/low and you want it setup as always on, look for a five pin relay.
I tend to use these Micro Relays http://easternbeaver.com/Main/Elec__Products/Relays/relays.html
Nice link Teazer I might go ahead and use those.
Sonreir
Do you have any wisdom on running High&Low vs High or Low. I was thinking of using a SPDT relay for the headlight, but thought it might be better to have both on with the high. I do plan on using an "on with ignition" light circuit.
Depends on the headlight you've chosen, but I'd probably go with an either/or approach on a stock harness. Stock harnesses usually use 16ga wire, which is good for around 6-8 amps. 35/35 headlight will draw around 5 amps if both high and low beams are on at the same time.
Let me know what you think of this:
I ran out of colors. So there are some duplicates, you should be able to get the idea. I'll also be adding some fuses, and some kind of security switch.
I've bypassed the starter solenoid because I don't understand why you need a switch for a relay for a relay. But I think I'm wrong here. Please correct me.
OK... so I'm not 100% sure I understand the drawing, but you don't need a relay for the solenoid. You can switch that directly.
You might benefit from a relay for the coils though, switched by your kill switch.
Also... I don't see brake switches. Are they implied?
I like these relays, they are pre wired 20/10 amp 5 wire including n/c n/o 87 and 87a
http://www.ebay.com/itm/DEI-8616-MINI-RELAY-20-10-AMP-PREWIRED-DIRECTED-BAND-NEW-HORN-HONK-VIPER-/141237434662?pt=LH_DefaultDomain_0&hash=item20e2683926
Good relay. Cheaper on Amazon, though (especially if you have Prime):
http://www.amazon.com/Directed-Electronics-8616-Relay-Assembly/dp/B000CJ05WW
Nice I used to install high end car electronics for 8 years. I used these little guys a lot. So small and easy to hide and bundle inline with harness
Thanks for the feedback. The two little switches labeled "stop" are the brake switches. I've since realized that those switches need to go to a hot lead, not ground. I forgot the whole charging circuit too. It'll take me a while, but I'll get there.
You could also used grounds to switch relays.
For more choices on the plug in relays, search "1 FORM C" relays. On Mouser, they are usually cheaper.
