CJ250T ignition coil help
leprechaun_sean
CJ250 'Rising Sun' project
HI!
First post!!
Basically, I'm cafe'ing a CJ, but the high tension cable to the left spark plug and snapped just before the cap. After speaking to a in-the-know friend he said it would be best to replace the whole ignition coil, and that any coil that had one ht lead coming off it should do the trick. Is this correct?
The CJ has two ignition , one to each spark plug, if that helps.
Cheers!!
Seán
The Yamaha XS650 coil is inexpensive, a good fit, slight bracket adjustment is needed.
The coil should be 3-5 0hm primary resistance, so not any coil works...The single output, 3 to 5 ohm primary works....Since I don;t know your location, I hesitate to recommend a vendor....
I'm in the UK, I usually just go with eBay for most of my parts
Its not 5 ohms, but would this work http://www.ebay.co.uk/itm/12-VOLT-HT-COIL-SUIT-PAZON-BOYER-3-7OHM-PRIMARY-14-5K-SECONDARY-COMES-WITH-CAP-/150780265459?pt=UK_Motorcycle_Parts_13&hash=item231b3443f3
Acceptable....It will use a little more current then the stock coil....If your charging system is in good shape, it will do just fine.
