CJ360 Cafe Build Down Under
thegiles
Hi everyone
Long time reader, first time poster... and first cafe build.
Picked up a nice CJ360. She wasn't running, but had good compression. Needed to get new battery, petcock, spark leads, fuel etc to get her started so decided to take a punt and just start the teardown without getting her started. I'm doing a nuts and bolts rebuild anyway, so figured it was probably a pointless effort.
There's loads to do, but got quite a bit done already. The rear axle took a beating to get out, probably due to rusted bearings, so on the hunt for a new rear axle :( The back tyre was completely bald, so the axle probably explained that - I don't think the back wheel has come off since the bike was first built!
A few pics below
thegiles said:
pointless effort.
Welcome to dtt.
I hope you dont find it to be a pointless effort, first thing on your list...crack open the top end. check the cam and rockers.
Thanks Trek97! Agreed, I'm hitting the engine next weekend. I'm keeping everything crossed.
But in the meantime, I'm tackling the wheels. I'm hoping I can get all the spokes off and get them zinc-plated. Watch this space...
By the way, does anyone know if the CB360's rear axle is the exact same dimensions as the CJ? The bearings on my rear wheel were very rusty and so I buggered the thread on my rear axle as I had to bash it out with a hammer (a rubber mallet wasn't strong enough). The CB's rear axle looks like it has a hole in the end of it to put a screwdriver through and pull out. Mine didn't have that, it was just a regular 'bolt' style.
I'm assuming the axle is the same size though?
Check a parts fische to see if they have the same part #. I can't answer that. But, sure seems like they would be the same. However I do know the CB and CJ frames are quite different.
trek is it true that a honda dealership would still do the recall if they had the parts for the cam guide? My 360 only has ~4k miles and doesn't have either recall stamps.
(sorry not meaning to thread jack)
good luck with the bike 360s are great little thumpers!
pretty sure all 360s rear axles are 17 mm, but you might wanna double check with crazypj
hmmm, If you had a good personal relationship w your local Honda shop AND they were open, selling new 360s in the 70s AND you had previously purchased a few Brand new bikes...I would be surprised either ways. If they did or If they didnt. but a bit more surprised if they did.
In any case, I wouldnt roll my bike into any Honda shop...for any kind of work. Especially motor work. Im sure they would give that job to the "new kid". And you would end up w broke, stripped, loose bolts. Hondabond clogging everything. proper tensioner and valve adjustment...forget about that.
That free tensioner could cost big bucks in the end.
Checked elsewhere and discovered the CB360 rear axle IS the same as the CJ360's. Just found it odd in the difference with the bolt-end shape/style.
Anyway...
What are peoples views on replacing the rear wheel damper bushes, where the bolts that hold the rear sprocket go into; and also the rear damper bushes for the swing arm that the bottom bolt of the rear suspension go through?
Are these 'the norm' to replace when doing restores and builds?
Sorry, dull question, I know! :)
Thought I should add a progress picture. Started to freshen up the forks with wet-dry paper. Hit one of them with 120 grit, turning out nice so far. Still has some stubborn black marks which dont seem to come out. Or maybe I'm just being a perfectionist? Next will go up the grits to 1200 then polish. Would be nice to get a mirror finish, but we'll see...
Actually, question: How do I get that bolt out (the one you can see coming out the bottom of the left fork? That holds the axle, not the one to drain the fluid.) Or is it not meant to come out?
W3qlKuVv09lBi2V803iR7ck2KhsQrrb-O0HBWT4xgHM=w617-h822-no
If your talking about the stud that holds the axel clamp...I see no reason to take that out.
You should be able to remove it by fully compressing the front shocks.
Started taking the engine apart at the weekend...
Has anyone had issues with getting the cylinder head off? The top end came off fine, in fact it popped off once all the bolts were loosened.
I've then taken all the bolts off for the cylinder head, but it wont budge. Tried hitting it in a few spots with a rubber mallet, but nothing.
Does anyone have any suggestions? Will heating up the gasket with a blow torch work?
