CJ360 first cafe build
the_photog
Hello DTT!
I'm new here, figured I would start up a build thread for my '77 CJ360. Engine wise she runs well and starts right up although the front break does not work so that is the number 1 priority to fix. This will be fairly slow going as my budget and time is not that great but hopefully I will have a beautiful cafe racer in a few months...(years lol)
So here she is after I got her home and removed the stupid lugage rack off the back.
And here she is after I stripped off all I could in the time I had this morning.
Initially I just want to get it in proper working order. So here is the list of work that should be done in the coming week or two:
[list type=decimal]
[*]Fix front brake (it has plenty of pad left I just think the actual actuator arm, or whatever it's called, needs adjusting)
[*]New front and rear tires (the existing tires have some narly dry rot)
[*]New rear shocks (the ones on there are toasted)
[*]Clean
[/list]A little longer out and less just get her running related:
[list type=decimal]
[*]Clean, polish, paint front and rear wheels.
[*]New handlebars
[*]new seat (debating on whether to make my own or get a pre-made seat
[*]get rid of rear fender
[*]Paint (yes it will be black, cliche I know lol)
[*]New gauges
[/list]And the long term goals:
[list type=decimal]
[*]Mikuni VM30 carbs
[*]Velocity stacks
[*]New exhaust
[*]Bored out to 378cc (extra long term)
[/list]That's about it, hope you all enjoy!
Hey it doesn't look like theres much else out there for the cjs so we might have to help eachother out. Sounds like we are in similar situations...time, budget and experience wise. I just bought my 77cj (same color and stuck front brake!) on the 21st and its going to be a cafe by next spring. I look forward to following your thread.
Alright! Another CJ360!
Also add a good carb cleaning to your initial to-do list. I advise against the VM30s as well, save you money for the overbore or something or the sort. CVs work really well on this bike once you get them dialed in.
Nice! I adjusted the brake cable which loosened the front brake up but still wouldn't stop. I replaced the brake pads and now she finally stops! lol
ndromb said:
Keeping the paint? That color is...unique.
I was going to keep it tell I got the bike done but I got bored without having anything to work on so the paint will be done before I start riding her again. (see below pic)
Thank you for the suggestions. I cleaned the carbs real good and it seemed to fix an issue I had with the throttle hesitating when I would let off the gas and just idle. So I'll be keeping the CVs on for a while for sure may switch to Mikuni's down the road but I doubt it now I might be getting a 750 or 1k to work on after this bike is running again lol.
Here she is as she sits now, paint stripped off tank and cleaned up.
The real progress should be made very soon. Today I placed an order for clubmans, new grips, bar end mirrors, new tires, and new tail light with integrated blinkers. The only reason I got the grips and mirrors is because it was a great deal packaged with the bars.
So here is an updated and changed priority list:
  • Fix front brake
  • New Front and Rear Tires
  • New Handlebars
  • New Tail light and blinkers
  • New Front Blinkers
  • Strip front fender and side covers
  • Build seat (decided I'm going to go the custom fab route)
  • Paint
  • New Gauges
  • New Controls
  • Rearsets!
Oh, and if anyone has some sort of trick to get the damn exhaust back on, please share! I cannot get it back on for the life of me! Primarily do to the frame mounting point under the bike (can't seem to get it to line up at all)
For the exhaust, start at the front and work your way back. Keep everything loose until you get the bolts started. Basically, attach the headers to the head, next is a mount underneath the engine, then finally the bolts holding the exhaust to the frame near the rear passenger pegs. After everything is started, go back to the front of the bike and tighten stuff down, front-to-back again.
Thanks for the tip! I haven't even worked on the exhaust yet lol but have been working on forming the seat.
Kinda playing around with the rear cowl shape and was wondering if I could get some opinions?
I went ahead with the shape and cut/sanded down to what I find acceptable. Here is how she sits now:
I had a bit of mishap with the fiberglass which was my own stupidity so I'll have to get more resin and start the fiberglass tomorrow.
In the mean time I decided to tackle the exhaust again and ran into another snag.
These bits here:
Fell off when I was trying to remove the exhaust so I never saw how the go on. Now I can't seem to get them to fit in no matter what I try, anyone able to help with how exactly these things go onto the headers?
Those little guys are a pain in the ass. They're not exclusive to the CJ either. They just press fit in. Attach the headers and thread in the bolts enough to keep things in place. Attach the other mounting points. When you come back to the headers, just fit two of those around each header pipe with the curled lip facing the front of the bike. Use a screwdriver or punch with a mallet or hammer and lightly tap them into the cylinder head as far as they'll go. At this point, you'll have to figure out a way to hold them in place (a friend is helpful here) while you tighten the exhaust bolts to factory specifications. Upon doing so, they should be held firmly in place by the pressure of the fitment.
And yes, I've done this and had them stay in place. They ARE a pain in the ass, though, so be patient.
Thanks for the advise! I haven't tackled this yet but one are question...do they go outside the mounts or inside? lol.
As far as the reset. I have done a few things. Got new headlight bracket and lowered the headlight. Got some switches for the new kill and high beam switch which will be on the dash. I decided that I want to make my rear seat right but don't want to wait so I will be ordering a roccity seat and working on building my own but taking it slow and using higher quality resin. Got the old handlebars pulled off, I'm running into an issue with the throttle cable (I CANNOT get it out of the throttle assembly...any tips there?) As got the gas tank about prepped for paint. Got some perches that are in the mail and will be there when I get home.
One thing I'm curious about is the throttle assembly. I've been looking at this one: http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-throttle-parts-oem-style-satin-black-honda-throttle-assembly-44-9777.html since it is OEM styled but does not have all the controls. I definitely want black. The only issue is it is backordered and have a feeling that mid-late July isn't going to happen.
I cannot find the OEM style assembly like this in black. I'm curious if this side throttle assembly: http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-throttle-parts-black-push-pull-side-exit-throttle-assembly-44-97780.html will work with the single cable throttle my bike has. Anyone know if that should work?
Sorry about the long post. Pics to come!
Prepping
Headlight mounted
what are your plans on that surface rust all over the frame?
what are your plans for the battery?
good luck on your build
this is great to see, I have recently purchased a 77' cj360t after toying with the idea of cafe'ing the usual CB 400s or Sr400 etc but opted for the lil cj beast :)
Hows the progress goin on your conversion? Is there any main points I need to be aware of? Am not new to bikes but am with customising them.
Good luck with yours!
Lee
