CL 175 RPMs skyrocket at start + only one piston firing
zcrenna
I think the title says it mostly.
In a nutshell, picked up the bike 2 weeks ago (73 Honda CL175) it ran fine then had starting trouble so I replaced the plugs and it started up easily. (during that time I did a little adjusting on the carbs, no jet work, just idle mixture screws)
the only problem now is when I start it the RPMs immediately climb up to 7K and don't come down.
I can give it almost full choke and it will idle at 3K for a minute of two and then stall.
I've checked the floats and it seems they are where they should be and the needles are springy.
I tightened the intake manifolds so there is not possibility of air leak.
I checked the jet needles and the clips on them are on the lowest notch (my understanding is that the lower the clips, the leaner the mixture).
loosened the throttle cable so there is a good amount of play and no chance of throttle being added automatically when I start it.
I have not tinkered with any of the jets since getting the bike so I'm leaving them alone for now.
The throttle cables on top of the carbs are turned all the way in (don't know too much about these yet to be honest, but flashing a light into the carbs while the bike is off I can see that the throttle slide is down and moves up easily when i twist the throttle.
smoke coming out of the exhaust does look a little dark, not black smoke but definitely exhaust that looks like it is running rich.
turned the idle screws all the way in then turned out only 1/4 turn and still have above problems
it also seems that the right piston is firing much more consistently as the right exhaust will get MUCH hotter then the left one (which only gets warm).
seems i have 3 problems; one piston firing and skyrocketing RPMs when i start it and what appears to be a pretty rich mixture.
I know that's a lot, its my first bike, and any help would be much appreciated!
Thanks in advance
Well, it seems I fixed the problem.
Looks like I put a throttle slide in backwards on my last reassembly... which was holding the throttle open fully.
Lesson learned.
And it looks like the other piston is working again, imagine that.
Idles a little high at 3.1K but much better. I put the idle screws at 1/2 turn out and it doesn't seem to lower it down to the 2K where I'd like it to be.
I left the clips on the Jet Needle at the lowest notch (out of 5). I am still a little unsure about these clips positions, putting the clip on the top notch of the jet needle means richer and putting the clip on the lowest notch means leaner.
If I have this backwards, someone please let me know.
I'd still welcome anyone's 2 cents on the "high" idle and the jet needle clips
Yep, you have it backwards: the clip in the lowest position is the richest setting, in the highest notch is the leanest.
As far as the idle goes, are you sure the idle screws are set properly? They physically hold the slides up when screwed in. If that's not the problem, usually it's a throttle cable issue.
