cl 350/450 "interchangeability"?
beard
pro blowhard
i have a 71 cl350.. got it for free.
im picking up a 71 or 72 cl450 on the super cheap.. its all there.. but motor is stuck.
on my cl350.. tank is dented.. banged the jets out... and cant find replacements... petcock reserve tube is hosed. foot shifter is broken... hand clutch lever is broken.. various things..
can i take the tank / foot shift / hand clutch / carbs off a 450 and put them on my 350? i suppose if i can get the 450 running then i make take parts off the 350 and put them on the 450?
is there any frankenstien things that people do when they have a 350/450?
thank guys
The tank will probably not fit without modification and I believe the 450 tank is a little bigger than the 350. The attachment tab on the back is definitely different.
I think the petcock is the same. The foot shifter and the hand levers are probably the same. If not exactly, they will probably work. I've heard of ppl putting the 450 carbs on a 350, but you will have to rejet them. A '71 CL450 will have 130/38 jets and a '72 CL450 will have 145/38 jets. I don't know what the 350 will need. You will probably have to buy a jet kit ($45) and try some out to get it right.
FYI, the rear swingarms are not interchangeable without mods.
350 jets should be easy to find. Ask in the "Stuff you need" section.
For jets check out Z1 (www.z1enterprises.com) $2 a pop you can buy as many or as few as you need and they probably have the jets you can't find. the tank might need modification but the only way to know is to try. the carbs would be tricky but not imposible. everything else should work just fine: clutch cables and handle bars are all the same size so I see no reason that won't work. I'm actualy running a foot shifter off a yamaha xs1100 on my cb400 it fits perfectly a honda to honda swap should work even better.
parts with red arrows are the parts im having a hard time finding..
these are parts that sit betweet the jets and the inside of the carb..(i belive they are called the jet holders..)
these are the parts u would see if u pulled out the slide and looked down into the body.
carbs had 25 years of gas in them.. carb cleaner did nothing..
i started trying to tap them out with wood.. then plastic.. finally got fed up and used metal.. ofcourse hosing the brass
Honda dealership maybe? I'd try to get the bigger motor running before I tried to put the 450 carbs on the 350, but you can probably make them work.
yeah i tried the honda dealer..
he said it was odd that the part on the left didnt even have a number...
i suppose most people dont take these out?
yeah i have no idea whats wrong with this 450 im getting it for 100 bucks.. so i figure if its a complete loss.. its not much money..
thanks for the help.
for a $100 there is no way it will be a loss. even if it's a total piece of crap you'll be able to take what you need and part it out for at least twice what you paid for it. shit I'd buy some parts if the shipping didn't kill me.
I would just ask around the forums for the carb parts. You never know what people have just laying around.
Fear,
I have a set of CL450 pipes. I have a stock set off of a '71 that I am cleaning up. I haven't yet decided if I am going to put them on my bike or keep the exhaust that is currently on there. When I decide, the one's I don't want will be sold.
can i take the tank — NO. At least not without some mods. Petcocks are different too.
foot shift — Shifter lever should be able to change over no prob.
hand clutch
— Should interchange fine
— I am in the process of doing this. You need the 450 manifold boots as well. If you just mount the manifolds then the butterfly levers of the carbs hit the 350 backbone tube causing major drag and not letting the carbs seat all the way in the boots. I am going to have some plates machined in the shape of the manifold bases that are wedged to angle the carbs out and give me clearance... winter project. You will also need a CB450 throttle cable cause the 350 cable is slightly shorter and it holds the carbs open... even with everything (adjusters etc...) all the way in (most slack).
Hope this helps.
– Woody
According to my dealer parts fiche, the petcock is the same between a 71 350 and a 71/72 450 (16950-292-000). They might be on different sides of the bike, but they are the same.
i have a 70 CL450. low vin number, 70th one off the block. ive been looking for a parts one for a while, either of the years for some misc parts. hold onto that bike, they are quite desirable. first off though, is your 450 a DOHC or a single?
serial number is 4116936
according to wiki its a 71.. and wiki is saying 71's are dohc?
i do know on the 450 access to the valves and adjustment nuts are majorly different than the 350
i got it kick over last night... compression L130 R125 intially... it didnt bleed off..
came with straight pipes... mufflers cut off.. that and the extra 100cc.. this thing thumps when u kick it over.. i love it.
gas tank is a nightmare.. carbs seem pretty good.. gonna hook it up to my trucks battery see how the electronics / starter go.. maybe even try to rig up some kind of gas tank and see if she will fire up..
knock on wood.. i think its a good start for $100.. figure if it doesnt work out i can make atleast 100 on parting it out..
Yep, looks like a 1971 CL450 K4. The year before mine. It looks like it is in pretty good shape. I hope you get it to fire up. If not, I'll buy it off of you for $100. ;D
