cl 360 engine seized...sitting for long time..
cafenewbie
Spend 2 Much time with the mouse in Hand
can anyone help me? Where should i start.
it will be the basis for my new custom ride..
thanks Steve
Start by taking the plugs out and shininh a torch in the cyls. If it's not too rusty, put some PB Blaster or Kroil or a similar penetrating oil in there and leave it for a few days. Try and turn the motor after that.
If you have no luck, then you will have to tear it down or junk it.
Black powder right in thru the plug holes......
Seriously, listen to Hillsy. After they soak, try putting the tranny into 2nd gear and just rock it back and forth. The engine may break free after that.
the engine in my current build was seized and I could see rust inside one cylinder. I tried the PBblast, let it sit.... still seized. dumped some motoroil in let it sit longer .....still seized. then shoved it out side under a tarp as the "Parts Bike". six months later I brought it in and started to take the head off to investigate. one of my friends was there and insisted that I try to roll it over. I finally I agreed just to humor him. Rolled right over like it had never had a problem. put the cover back on- compression checks out- starts first kick.
So moral of the story, pull the plugs, try to peek in, dump a bunch of oil in there, and then be patient. Also as stated its best to rock the bike back and forth wile in gear rather than jumping up and down on the Kick starter.
PB Blaster has worked for me on serveral occations. Just spray in and let sit. To that twice a day for a week, maybe on day 3 try to turn it over. If after a week if won't budge, its time to crack a beer and pop the top off the engine to see what the damages are. The rings in these engines combined with the cast iron liners will just glue themselves together sometimes.
If it spins easy the 3rd day, see if it will run. If it takes till the weekend I would still pull the top and see how messed up things are.
After talking with Steve through PMs, I believe all he has is a motor, so no rocking back and forth.
Then there's no frame in the way..... I would say soak the cylinders for a week or so, then pull the head cover off and just get to work
I thought mine was seized but it ended up being something in the starter drive that was jammed up. Hooked up a battery and popped the thing once and everything was fine.
