CL175 AC generator rotor removal
facefirst35
Coast to Coast
I'm tearing down the motor on my CL175 (first time doing this) and have run into a minor snag. I'm trying to remove the AC generator rotor. In the manual it says that I need to use their tool to do it. Is that the case? I'm sure someone here probably has a better way of,doing it without having to buy the tool.
I haven't - but if you search the following forum I expect you'll find the answer:
http://www.hondatwins.net/forum/viewforum.php?f=31
You will want to use a two piece gear puller and a slightly longer m8 bolt. Fit the edges of the puller just behind /between the rotor and the sprocket. The bolt threads into the crank, then the pullers nose sits atop the bolt. As you tighten the puller onto the bolt make sure it isn't bending the bolt.
They will take a lot of torque, and usually pop when enough force is applied. Once its broken free, back the m8 out a little and repeat the process until it can be removed.
The first time is the toughest.
The puller I bought was from harbor freight.
Dunno if this helps but when I did it to my cb360 i used the rear axle, cranked away and it popped off
