CL350 Carb jets Sticking
fluke12
Hello all, I've finally gotten around to cleaning my carbs and i got to the point where i'm supposed to push out the jets from the top with a plastic rod or something that isn't metal and they aren't budging. Am i missing something or what? Would it cause any problems to just soak it with jets still in?
This is the same for both sides, so it feels like i'm missing a step or something?
BIG thanks for the help.
Try soaking the whole body with jets in for a little while and see if that loosens them up.
Yeah, I tried soaking the body after I pulled all the rubber parts for probably 20-30 min. Maybe that wasn't enough? It's in there so tight that it feels like its welded in. Any other ideas? Maybe longer soaking? How long? The carb LOOKS clean, it's not like all gunked up.
I usually use a chop stick to drift out needle jets in Keihin carbs. They happen to be almost the perfect size and are square at the end.
How hard is the normal "push"? I kinda assumed I should be able to push it with my finger. The float needle pieces fell out easily like no need to use plyers at all. I'm not even sure this is where my problem actually is. But at least I KNOW this isn't right
Do not use pliers to pull carb parts out unless you are very very careful., It's very easy to damage parts. I usually turn the carb upside down and strike the chopstick on the workbench. It shouldn't take a lot of force, but they don't always just push out.
Thanks for the info, I'm gonna try the chopsticks. Just an FYI, I finally ran some gas through the carbs after soaking the body with them stuck inside. That plus new plugs = 1 kick! So it must have done enough. I still want to get them completely clean.
