CL350 exhaust pipes bracket
Jramos13
hi well i think im gonna go mufflerless, im going to solder some VW tip on my pipes and wrap them, the inner ID is 1" so i hope that generates enough back preassue if not ill add a lollipop baffle, anyway, is it safe to run without the muffler bracket? the one that bolts to the swing arm, since i wont have the extra mufflers weight i just want to know if its safe for the heads
thanks!
I would support the pipes some how. You don't want to put the studs in the head under those loads.
You staying with the high pipes or swapping for CB low pipes? My 63 250 CL is running same era 250 CB low pipes, which have tabs that match tabs on the lower chassis rails. Simple bolt, spacer and nut, takes all the weight off the exhaust ports.
Not sure why a factory CL chassis would have frame tabs for factory style CB pipes, maybe frame tabs came with the header set (Rocky/Nempco from the early 1970s).
You need some form of rear or center support, regardless of your pipe style. Flat bar aluminum is cheap, easy to work, easy to polish up. Just a brace off the engine would work for high pipes.
got it, the CL has a pipes bracket to support them from the swing arm, ill guess ill put it on then!
