CL350 getting spark!
beard
pro blowhard
i am having some issues here.
yes i have a clymer and a shop manual
im not getting spark to the brand new plugs
i saw that sometimes the kill switch messes things up
i started at the kill switch and would check the ohms from the switch along the wires.. i was getting some numbers.. meaning there is connection there
also in the above pic.. when i would switch the kill to on.. i would get power to the points.. no power when the kill was off.
so i would guess the kill and ignition switch are doing what they should.
something also strange.. i was playing with the timing.. and it seems when i have a test light (neg to the block and the positive to the red arrow above.. the light is on whether the points are open or closed.. from what i read.. the test light should only come on when the points are closed
what the heck am i doing wrong.. id say im good with my hands.. but this is my first time dealing with a motorcycle/ points / carb.. its just been soo frustrating.. every bolt on this thing takes a hammer or a drill to get off lol.
any help or guidance would greatly be appricated.
any way to test the coils / condensor? with a volt/ohm meter. battery is new.. with the ignition off the battery is giving me 12.75volts the head lights are bright.. the horn doesnt work.. starter turns the engine over.. the bike spent the last 25 years sitting in a garage.. carbs have been pulled and cleaned.. im just working on getting a spark right now.
if i use the starter.. sometimes the bike makes a noise like a barking seal. my kids say the bike sounds like an elephant.
also i cleaned the oil filter thing.. and since then (not sure if they are linked.) but when i kick the engine over.. after i kick i hear this metal intertia noise almost like something is rubbing.. or theres marbles in the gear box. hard to explain
sorry, theres alot above.. but thanks
good read (although for bwm) for motorcycle coils/points rookies
http://w6rec.com/duane/bmw/points/index.htm
