Frequently the topic comes up about a modification that can be made to the electrical to allow the full charging capacity of the alternator to be used 100% of the time instead of only when the high beams are being used.
The modification is nothing more than disconnecting the wht/yellow wires that come from the handlebar switch and connect to the main wiring harness in the head light shell. After disconnecting those wires you then connect the wht/yellow wires in the main harness together. The remaining wht/yellow wires from the handlebar switch are left unplugged in the headlight shell.
The following picture shows the resulting wire connections.
I hope this helps and I'll make this a sticky for future reference.
