need4steed
Active Member
i have a 73 cl350 with a blown piston. so i took it all apart and i have a question about the clutch setup. I took the cover off on the chain side and when i did, the long rod that runs through the whole motor came out with it. this rod is what allows the motor to go into nutral to shift into the next gear. my question is, can i just put that rod back in, and when i do it just spins. Is this normal? thanks
