Cl350 not charging propperly, video inside
Jramos13
Hi guys!
Today i finally got my plates after my build!
I was test riding it on the street and i noticed that my gauge lights start dying, while getting home i hit the accelerator and it just dies on me, i tirn the ignition off then i turned it one the lights came back.
I have ricks regulator and stator, i chek the stator at ohm and i get .8 in the 2 phases nothing to ground, i did the diode check in the rectifier and i get 485 on both, while running the ac volts are running from 10 to 15 and the lights dim a lot and get brighter when i accelerate,
Now in the dc bolt to the battery i get 7-8 bolts while idle and goes up to 9-10 when i accelerate, when i charge the battery with the tender , after a few minutes with the tender the battery goes up to 12v again, it runs great but after the charge is gone the problem i mention on top starts
Any ideas?
Heres a vid of it idling, as soon as i hit the throttle it dies:
http://youtu.be/sKpdFmDOcww
This is the dc voltage:
http://youtu.be/57ZbHA1qgaU
When it dies the voltage goes up
Here's a link to a good electrical fault finding guide:
http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
It's mostly for newer bikes, but is still very applicable to older bikes.
Excellent chart! Thanks! Apparently i have a bad RR, i wanna double chek the battery also before i do anything else!
If im using the ricks stator can i ise the kholer unit? It only has 1 input for the stator and i got 2 cables from it
Your stator is (probalby) good. I say probably because you cant assume anything, but ive never seen one go bad. AC volts out engine are anything from 30 to 100. Your RR is dead 99% sure.
YES. you'll have to combine white and yellow to one wire.
check this:
http://www.hondatwins.net/forum/viewtopic.php?t=14530
If he has Rick's Stator, it only has 2 wires...
For the OP, it is a one phase stator. 2 Phase electric technically doesn't exist. Even the Stock Stator is one phase, but how many coils in the stator that are engaged is why there is 3 wires on the 350.
The Kohler regulator has 3 connections plus you need to ground the case well. Usually the 2 outer connections are AC (The 2 wires from the stator connect to the 2 outer connections). The center connector is 12V battery Voltage...That should go directly to the Battery + terminal. A nice 14g wire or better from one of the mounting bolts to the Battery (-) terminal will assure good performance.
Also, a weak rotor (Magnets weaken over time) will also reduce output.
