CL350 oil Circulation Check?????
liceyscrub
And now for something completely different
So you know that bolt on the head next to the cam cover on the points end of the CL350, I have been informed that you can remove that bolt to check for oil circulation to the top end. If I got my bike running, how much oil should come out of that hole and how long shout it take for the oil to come out. I had a leak in the cam cover seal at one point during my rebild and oil was spewing, but this time I got that fixed and removed that bolt and did not see any oil? am I off base here????
Now I want to make sure oil is getting to the cam and I thought this is how I am supposed to check, but not sure what to look for. Any help on this???
I lost that bolt while riding once. Half of the oil sprayed out onto my pants before I pulled over at a gas station and refilled. Best way to check for top end circulation is to remove the tappet covers while motor is idling. Look into the inspection hole and you'll see drops of oil spitting onto the the rockers and valve tops. Or put a fingertip on top of the rocker, don't worry, you're finger won't get cut off. You're fingertip should be covered in oil.
10-4 I will check. I suppose temperature of oil may have something to do with how long the circulation takes. It is snowing outside and bitterly cold even in my garage.
I'll start by saying I have no clue if this is a "correct" thing to do, but mine stopped spitting oil out of the top bolt and started overheating quickly (stopped oiling the top end I assume)
So, not wanting I tear it all the way down, I grabbed my air compressor, set it to 40 psi and with a rubber nozzle I blew air into the hole with the engine idling. whatever was blocking it popped right out and she started spewing oil out the hole and all was well.
I then changed the oil an ran some Seafoam through the oiling system.
So, pulled the oil filter cover off and blew air up(the higher hole) and got air out the bolt at the cam cover, and then "dry started" with the bike off and oil comes out the bottom hole of the oil filter cover. That makes me think all is good. I also tried to plug the hole with my finger while turning the bike over and it gains pressure, so I figure the pump is fine. I then put the cover back on and start the bike, I run it for 3-5 minutes without oil comming out the bolt hole at the cam cover or anytime I took in the tappet covers off.
Does the filter need to be primed? The pump is pumping so I know the oil viscosity is not the issue, but I am SOL...any other idea.
I cant figure this one out, and dont want to burn the motor up and rebuild it....again
Has anyone ever heard of the oil filter restricting the flow or not operating and preventing oil from getting to the top end. That is about the only thing left and it is clean. I got a peristaltic pump and pumped oil through the top hole of the oil filter cover and It comes out the hole on the top end by the cam cover. The bikes oil pump I also verify that it works, but when I put the cover on....no oil to the top end.
seriously dumbfounded(code for angry, pissed, ect...)
Are you using a gasket for the oil filter cover? If yes, you need to align the oil passage hole.
oil goes from the pump through the filter to the transmission as well as the top end, if your oil pressure is very low, you may lose top end oiling, even though oil is flowing. you need to check the condition of the oil pump pickup screen, then check for any obstructions in the oil passages around the rearward outer engine studs, my guess is your screen got plugged, then collapsed, then let crap through and the crap blocked the orifices next to the studs that feed the top end, blowing out the system from the top down would only momentarily dislodge the crap, as the oil flowed, it would reseat itself in the orifice
Spent the afternoon troubleshooting and thanks the the advice above figured it out. I check the screen before assembly and it was clean, but man was it plugged this time. Probably should change the oil and check the screen numerous times in the first couple hrs of run. Never tore down an engine before, but learning a little more with every issue. Thanks RocCityCafe.
There's probably a lot of sludge at the bottom of the sump but the baffle plate is bolted and peened on. A bad design. I've gone through the trouble of grinding down the peens and drilling and tapping holes to have the baffle removable so I can clean the sump.
