cl360 throttle cable (b) / carb trouble
designmaki
I am totally new to motorcycles, but I have been working on water-cooled vw's for some time so I am pretty handy.
I recently purchased a cl360, the bike started fine.. seemed like a good deal for $500. I loaded the bike up and came home, once I arrived I looked over the bike started it up and went for a short ride around the block. I noticed the rpms staying high on the bike when I let off the throttle, so I got it back home pulled it into the garage and started to check it out.
This is what I found, the push cable (cable b) was not connected to the carb at all. It appears the cable broke at the throttle grip area, I purchased a cable off ebay that was NOS and started to install it... well not so much luck here.
The cable seems like it is to short..I measured the housing up to the old housing and it appears to be the right length. I do not have the inner cable from the old one so I can not measure that up,
If you have any suggestions or any info that you can give me that would be awesome..currently I have the whole carb set-up removed from the bike ..but still cant find anything that makes sense to me.
You have checked cable is in correct position at throttle tube?
'Pull' cable goes in front hole, may have been relocated to use single cable?
Adjusters are fully backed off?
It is correct cable for model year?
I'm not sure if CL had different sized pulley wheel, that would mean different length inner wire
thanks for the help!
seems fine once again, hopefully when i replace the (a) throttle cable its goes smoother.
whats the best service manual to get for the cb360/cl360?
