sleazy
"everyone has a plan…"
howdy howdy howdy-
first post on this here forum, so be kind. i heard this is THE place to ask questions like this as you guys have basically done everything, every which way. here goes-
i have a '71 CL450. need fork tubes. bad. like really bad.
i can find CB450 fork tubes all over the place -but the CB450 is a straight fork tube, whereas the CL450 fork tube does this weird "neck-down" at the top triple clamp...
so- what i'm thinking about doing is- getting CB450 (straight) fork tubes and a CB450 top triple clamp. -problem solved! (right?)
are CB450 and CL450 fork tubes the same on the bottom? will a CB450 fork tube/upper work with my (drum brake hardware attached) CL450 fork lowers?
and will -essentially- an upper triple clap with a larger fork hole be the piece that makes all this come together?
many many thanks in advance for any and all help.
here's the (BEFORE) pic of the project:
http://i1131.photobucket.com/albums/m545/schmuzzy88/003-3.jpg
