CL450 clutch lifter rod and oil filter PICS!
DHolbrook
Active Member
Two questions:
Is the below pictured clutch lifter rod usable? It was working when I took it apart, then I noticed the "repair" from the PO. Go with it?
Also, how do I bend back the tabs on the washer behind the oil filter nut (the one that needs the special tool)?
THANKS!
Well, its hard to say about the clutch pushrod. I'd check the weld by putting it in a vice and give it some tugs. If it's solid, your good to go. There's no oil seal on the place where the rod is "damaged"?
As for the oilfilter, i used a screwdriver and a small rubber hammer. The same way you did it as i see in the picture ;) There's no 'by the book' for that sucker as far as i know. Do you have the tool btw?
You can buy a cheap big socket, like 24 or so,(just one with the same diamension as the nut) and use the anglegrinder to make the tabs. Or buy one ofcourse, but that would ruin the fun of getting it loose tremendiously ;)
Right, so I tested the rod in a vice and it seemed very sturdy. I was worried by the little pock marks and the crease line, so I filled it in with JB Weld and eventually sanded to like 1000.
