CL450 Exhaust
Disliked23
So I picked up a 1970 cl450 parts bike for 50 bucks this weekend (plus four crates of part and an extra bottom end!) and it has a scrambler exhaust that is in pretty good condition but has some rust here and there that the wire wheel won't remove. Well, it removed it but the chrome is gone too in those spots. The covers are in good condition though, and I want the CL exhaust on my cb450 since I can't find a good 2-into-1 for a reasonable price. Since the headers are in so-so condition (scratches, minor rust) and the muffler is in so-so condition (ditto) I'm planning on wrapping the headers, painting the muffler black, and leaving the covers chrome and the tips chrome. Here are my questions:
1. Painting over chrome? Should I just sand it down and use a heat-resistant paint? How sanded is sanded enough?
2. Mounting to my cb450? Gaskets, etc. I'm not entirely sure what the mounting process entails.
3. Do you guys think I will need to do any carb modification (rejetting, etc.)? Carbs are good right now and my cb runs pretty darn good, and since they are the same engine it seems to me that I won't have to change anything. Sound right to you guys?
Again, thanks ahead of time for the help!
-Ty
If you're planning any kind of surface coating, you'll be well served to have the chrome chemically stripped, they take them to a powdercoater and have they JetHot coated. It's a great heat shield coating that looks good, then you can wrap your pipes, they'll be MUCH cooler to the touch and your exhaust velocity will improve which is good for scavenging.
If it is a K3, then it is the same as the one I am getting ready to put on Nixon. I haven't gotten around to putting it on yet so I'm not exactly sure about a procedure, but I would guess you just unbolt the old one, and bolt up the new one. Besides the engine, it only attaches to the left shock stud and a tapped hole in the left passenger peg bracket. That hole should be there on the CB as well. The parts fiche shows two gaskets at the engine mount. I'm hoping mine will be OK and I won't have to replace them. I know I probably should, but I am a cheapskate ($6 each). Also, one of the headers can be removed from the muffler. I don't think you need to remove it to mount it, but I'm not sure. They would probably be easier to wrap if you do. Where the header goes into the muffler, there is a gasket. I took mine apart to clean it and just ordered that gasket from my honda dealer yesterday (18392-MK4-000 $10). The flanges on the muffler under the clamp where the header goes in are pretty rotten on mine but I'm hoping there is still enough to hold the header firmly.
You do not need to take the heat shield off to mount it, but you will probably need to in order to wrap the headers and paint the muffler. I had a lot of trouble getting the heat shield screws out and will be replacing them.
"The parts fiche I use from my honda dealer"
You should not need to re-jet for the CL pipes. I'm pretty sure the jets did not differ between the CBs and CLs. I think stock K3s were running 130 main jets.
Thanks! It is a K3. I had a horrible time getting the screws out of the heat shields on mine as well. Actually ended up breaking one off on the rear one. Days and days of pb blast and the sucker still snapped. Luckily there's five screws holding that piece on so I'm just going to remount it without the particular screw. Shouldn't be a problem.
I don't feel like you would have to remove the header that comes off just because I was easily able to remove the exhaust without doing it. I didn't think it would need to be rejetted either, so I guess I'll just try it. All the mounts are available on the cb so the mounting part for the muffler won't be an issue either, I guess I was just wondering about the area where the header attaches to the engine. It looks like on the bike I pulled it off of that once you remove the clamp with the two nuts, the area behind that is like a 3/4 circle that the header goes into, then another piece of metal that covers that 1/4 of the hole that is open. I got a clymer on the way so I hope that details the process of removing/installing headers.
I'm doing this on the cheap, so if I have the chrome chemically removed will that be an expensive process? If so I would just rather wrap without stripping the chrome. Thanks for the info on that though. Do you think the gains from exhaust flow are worthwhile?
Still confused about painting chrome. I'll do some more internet searching.
I broke one of my bolts too. Actually, I had to cut the head off of it to get the shield off. A friend of my dad's drilled it out and re tapped it for me.
I haven't looked at the mount at the engine yet. I was just going to pay attention to how it came apart. If I remember tonight, I'll check my Chilton's.
If you want to go on the cheap you can use muratic acid to remove the chrome (any hardware store should have it for real cheap) Brush it on and leave it sit (use gloves and a mask). When you think its ready (this is the part I'm unsure of) hose it off then sand. I would guess 160 grit. I've not used this process but JRK recommends it. You may PM him to get the exact how to. When the chrome has been removed, Wash well with dish liquid. prep them with wth denatured alochol. Wipe them down a few times with that. Prime with high heat primer, then paint with high heat paint. Done...one the cheap.
To keep them from rusting.
If you happen to leave the bike out in the rain, it will soak through and get to the metal. If you don't run the bike after that, the moisture will sit there and rust them.
I hope the muratic acid works, I tried it once but was unsure. I was stripping pitted chrome off an Indian fender ornament to copper fill the pits and probably didn't leave it on long enough. It cost me $25 IIRC to have a plating shop strip the chrome, I imagine it'd be something similar for your pipes.
