cl450 help!
ozarkansas
Im starting my very own build. it is a 73 CL450 and we are in love. the only thing ive done to it so far is clean up my fuel system (tank, lines, carbs). i put it back together to see how she runs. great except when im in 4th or 5th and i get on it the rpms rev but i dont go anwhere (slips?). its like someone grabs the clutch everytime i try to get on it. can someone tell me if this is my tranny or my clutch?
its probably the clutch, i have read the cb/cl 450's have weak clutches. start by checking out the springs, then if you don't have any luck you may have to try a new clutch kit
exactly what i wanted to hear... thanks, ill do that. probably shouldve done that in the first place but outta my whole mechanical expiranc i have none with the clutch (springs and plates and what not)
its definitely the clutch slipping.
I would pull the clutch, inspect the plates (check they are correct thickness etc against the manual for your bike) then throw in some good high performance springs.
your clutch will be harder to pull, but it wont slip. also you will build the muscle quickly.
Your friction disks are probably just worn. Good news is it's not a tough job and it won't brake the bank either. I'd go with Barrnet Kevlar disks and performance springs. A lot of times you can just clean up and reuse the alloy disks if they meet the proper tolerances and aren't warped.
If your getting clutch slip in the higher gears its due to it not being adjusted properly. The old hondas can be a pain sometimes to get correctly adjusted.
I dont think your friction plates are bad.....if they were....youd have clutch slip in every gear.
much thanks everyone.good call too. next time ill dig a little deeper into my bike before i ask for answers. one barnett clutch kit ordered along with clubmans and a petcock bowl and gasket.
really? makes me a little nervous but i geuss a spring is a spring... i have no way of telling if mine are wore out. they seem fine but while im in there i want to make the best of it, you know?
