CL450 Honda project bike 1971 SOLD
pacomotorstuff
Coast to Coast
1971 Honda CL450 project for sale.
Completely dissassembled but 99.9% complete (I've moved 9 times since I started the project, so the odd small bit may be missing). Restorable or an inexpensive track bike.
The following new parts are included (they have never been installed):
Powroll 500cc kit, new pistons and rings, cylinder bored out to fit.
Valves and valve guides. (guides have been reamed to fit).
Barnett clutch friction plate kit.
Honda clutch springs (may be heavy duty- I can't remember).
Camchain
Aluminum finned alternator and oilpump covers.
Aluminum finned exhaust pipe clamps.
Engine socket headed screw kit to eliminate the cheesy philips screws.
Gasket sets, almost 2 complete (guard dog ate part of one set).
Rear sprocket, aluminum, Circle Industries.
Rear brake shoes, Vesrah.
Drive chain RK.
Koni shocks (but probably need new seals as they have been in storage 30+ years).
New Honda 450 DOHC emblems for the sidecovers (ouch were these expensive!).
Tapered steering head bearings.
Chromed Cafe headlight mounts.
Not so new stuff
Tank will need a good cleaning (light rust inside) and bike will require paint.
Crankcase has had a small weld / machining repair at the output shaft but
bike comes with a spare crank and cases from the late George Pedzinski.
Left side upper frame shock mount will need repair- a previous owner looked at laying down the shocks and started by whacking off the shock mount (I may have the stud that was removed- I'll look around).
Handlebars are pretty cheesy and would need rechrome or replacement.
Exhaust pipes are flat black high temp paint with chromed megaphones.
No airboxes, starter motor, fenders or seat, but I can supply 'glass parts at an additional but reasonable price.
Ownership is in my name, so easily transferable.
Will be able to email photos tonight if you email me at pacomotorstuff@cogeco.ca
$600.00 firm- which doesn't even cover the parts and labour costs I have in the bike so far.
Pat Cowan
905-873-3171
Re: CL450 Honda project bike 1971
WOW.. thats a fantastic deal!!.. I hope someone here gets that project!!
