Cleaning a DIRTY chain
hecklejk
I am wondering what the best way to clean an old chain is!! I just removed the drive chain so I could pull the motor to rebuild it and the chain has about 30+ years of gunk built up on it! What is the best way to clean the chain? I was thinking that soaking the chain and just taking a wire brush to it would do the trick, but I am not sure what to soak the chain in! Also once the chain is clean should I lube it with anything before I reinstall it??
I went old school and got a gallon of kerosene from the gas station. Soaked the chain in that and used a wire brush to clean things up. Worked great. Will lube with PJ1 blue label chain lube before reinstallation.
CC
CC
That was the plan for me as well, just didnt know weither to use kerosene, gasoline or something else!! Thanks
I used WD40 and a wire brush. Hosed it off, and then dried with an air gun. Then lubed with the chain wax. Looked like a new chain.
You are never supposed to use WD40 because it does something weird to the o-rings inside the chain, but I am sure people do it all the time so it is probably not a big deal. I used simple green for my chain, gave it a couple soaks and it did a pretty good job. Plus simple green is water based and not harmful to the enviornment.
I don't have an o-ring chain.
No, he has a no-ring chain. Stock chains on old bikes are just greasy chains - no rings of any sort. On some bikes swapping to a modern sealed chain isn't an option due to the extra width of the chain (CB550 for example - the wider chain will eat a hole in your engine case)
Kerosene will clean it off nicely, but before you bother, check the stretch on the chain and sprocket wear - might be time to replace the chain and sprockets.
Soaking in simple green overnight works pretty well. But there's water in simple green, so don't leave it in there forever or its going to break down the metal eventually.
I sprayed mine down w/ Dupont Teflon Chain lube after cleaning.
Kerosene is better than gasoline. Less vaporization and thus less chance of fire. Also a little less of a health hazard. Hell, my great-grandmother used it as an antiseptic (and she lived to be 99 :))
CC
