Cleaning a greasy old loom
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
So I have this old loom laying around and I want to clean and refurbish it...new connectors,cables colours stay stock.
I would like to remove the grease and dirt....can I bathe/soak the loom in wd 40 or any other liquid to remove the dirt in order to make it like new again?
Gesendet von meinem SM-A310F mit Tapatalk
I soak the harness in a degreaser like Purple Power diluted in hot water. There's also stuff called Oil Eater that's really good. Then spray all of your connections with DeOxit.
I usually remove all the 4/6 pin ends and the heat shrink, clean all the wires and plastic with simple green and alcohol for tough stuff. Use a small file or some sandpaper to clean the connectors followed by some contact cleaner, then re-wrap in either heat shrink or dry vinyl loom tape.
Brake cleaner is also good for removing gunk on cables. Squirt a bit in a rag, wrap it around the cable and rub the crap off.
I agree with von. CRC will get that grease off. I disassembled mine completely, wiped down each wire, changed connectors where needed and then ohm'd them out with the fluke. The grease really doesn't penetrate the jacket on those wires so they clean up easily. I'm about to do the one on my Daytona Special too. Fun fun.
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
I find brake cleaner is better than CRC because it leaves no residue (helpful if you are planning on re-taping the loom).
Thanks guys for the help!unfortunately many of the stuff you get in the states is not available in europe.
I filled half a bucket full of gasoline and dipped the the loom in there...got nearly all residues of tape goo off...
Then i used compressed air to vaporize the gas.
I will clean the contacts with contact spray and maybe redo the process w
ith a degreaser in hot water (even though I dont like the idea of water touching electrical components).
Any smart tips on a good dry tape that wont goo all over the loom?
I don't know if you can get DeOxit, but it's something that gets rid of all the oxidation on the exposed connectors and makes them shiny and new again. I use it when restoring vintage stereo equipment.
Linerless self fusing tape. No glue. Sticks only to itself. Insanely weather/oil/fuel resistant and as an added bonus one wrap will insulate up to 700 volts! Lol. It's not cheap, but there isn't much better out there.
+1 on the fusing tape. you can get it in rustoleum brand that is cheaper than the 3m and 95% as good. It is great and leaves no glue mess if you need to remove it for repairs etc. I get it for about 8 bucks a roll CAD so 4 euros or 5 US.
Anything but jap wrap. 3m 33 would be good to use also. It may get gooey but it would take awhile for that to happen. You shouldn't have to take it back apart again for a long time anyway and with the low voltage on the harness, it shouldn't put off enough heat to break the tape down. 130c is great too just a tad bit more cost.
Are you going to buy new a jacket for it too?
