Cleaning electrical plugs/harness
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
hey guys!
i´m currently trying to restore the cable harness of my RD.
what kind of solvent would you guys use to get 30year street grease off?
its really really sticky and i thought about using brake cleaner cuz it will evaporate and wont hurt the contacts....
i would like to soak the contacts cuz there pretty much dooked up inside...what should i use?
I do what I saw the Dime City guys post about a while back: fill a container up with WD-40 and soak the harness in for a few hours. Pull it out and wipe / air it off and your done.
i think i´ll go with priming with acetone then using wd 40 for the finish...
another question:i want to extend some of the cables in my harness...so i need to insert a longer piece of cable.
what would you guys do, solder the cables together or use this two sided squeezing connectors?
Depends on which connections you're wanting to alter. For low current stuff (anything that isn't the headlight, ignition coils, or horn), the splicers are fine. I'd go with a connection of a different type if you're doing something higher current. I try to avoid soldering when possible.
i´ll definitely going to enlengthen only the low current ones.
my plan is to hide them in a box under the seat.
so ill stick to the splicers and same thickness cables.
+1 on acetone. WD40 is my absolute most favorite chemical ever (well, water is ok too I guess) and I am convinced that it improves everything it ever comes in contact with. . . except not this. You will want to re tape your harness after you do whatever you are doing, and you will want the wires totally clean and ready for tape to stick to. WD will leave an otherwise good film (bad for tape). I like solder and heat shrink for lengthening wires inside looms because you can make a reasonably small splice that does not make a big bulge. Take a loom entirely apart and you probably will see the factory does a lot of this. You do have to know how to do a proper soldering job though. There is a colossal difference in electrical tape. I use 3M brand super 33 (or thicker) because of quality vinyl and great adhesive, and no doubt there are other good ones, but most tape is more of a problem than a benefit. Most tape leaves nothing but loose wires and awful goo behind after a short time on a bike. I have never had an issue with "high current" items and soldered connections, but no doubt there is more concern for a soldered connection. My only comment here is that if for whatever reason there is enough heat to disturb the solder, there are likely other problems that are more important. I am also much more likely to replace the entire wire if I need it longer, but most of the time I have a loom totally apart anyway. I will add also, that I have had my share of soldered connections totally massively fail in service - but only in electronic gear - never (so far) on a vehicle! Lastly, I buy marine grade wire, which has fine strands and is tin plated. MUCH better than plain copper for life expectancy. More expensive, but not awful for small projects like bike wiring. (ok, if you are going to buy a spool of every color and stripe combo you will need, it will be about a million bucks, but you can usually get just a few bits that will do at a marine supply).
