Cleaning/Polishing
Disliked23
Just wondering what you guys generally use for cleaning/polishing parts. Give a newb some tips on what to use! I got some CLR to remove some of my rust, but I want to get the rest of the metal nice and blingy.
Thanks in advance!
I am cheap and do everything by hand. I remove the parts if possible, then sand them down starting with 220 grit sandpaper and work my way up to 1000 grit, then I use steel wool and finally aluminum polish to get a reflective surface. A buffer wheel would give you more of a mirror finish if you have one.
Yeah it will make it nice and shiny haha!
But in all seriousness, you need to start with a low grit (200-400 range) and end up with a high grit (1000 or more) to get all of the scratches out. Steel wool improves the finish slightly and buffing compound + lots of elbow grease gives you a somewhat mirror finish. Take your time and do not go onto the next higher grit till the surface is consistent. Take your time, if you rush through it your aluminum parts will look like crap i.e. like you dropped the bike
Oh yeah and when it comes to chrome, I don't sandpaper it, instead I go to town with a ScotchBrite pad.
Look at this link and you´ll have parts sparkling like stars on acid.
http://www.thegsresources.com/_forum/showthread.php?t=136634
JF
