clubman handlebar with front brake reservoir question
indyjoiel
Hi
I am changing my handlebars on my 78 GS750. The front brake reservoir once I change the handlebars will be on an angle and not level.
My question is will this affect the braking performance or will it just be a pain in the arse when I need to refill brake fluid?
depends how silly an angle the bars are, if you open up the top of the reservoir you'll see a couple of holes in the bottom of it, these are where the fluid passes thru into the cylinder itself, as long as the fluid covers these holes during normal operation you'll be ok, and yes it will be a pain in the arse to bleed them, been there done that. you'll need to turn the front end to the left with the bike on the side stand and it should bring the m/cyl to about level.
have fun
Yeah but bleeding and maintenance should be like item number 10 on your list of thoughts of switching to that. Yeah it may be a little difficult but what hydraulic system isn't. I personally love the hydraulic systems on bikes and hydraulic clutch systems too. I have hydraulic clutch and brake on my 87 super magna and there is no center stand option for most magnas so you have to put it on the bike jack just so, turn the bars this or that way, screw the lid on with one hand so you don't lose the current angle you have and spill brake fluid all over your tank and hope you don't drop a screw in the process.. But really how often will you have to do that? Every 5 years. I say its worth it if you love the look...
Like spotty said as long as the fluid is past the two holes where the piston will move fluid for pressure then it will function. I've had the line very tight and really curvy on some bikes to get it to work and it will. Just do what you like the look of best. You'll only be pissed at yourself every 5 years or so when you clean/drain/bleed again.
