Clutch cable is too loose!
CB360ty
Active Member
So I just took my clutch cable off to put lube in it so it will pull easier and after I put it back on I pulled the lever half a dozen times and then after the 6th of so time I herd a "ping" noise followed by the lever being completely loose. It now won't retract and just stays loose. What did I do and how can I fix it??
Thanks!
-Ty
If cable broke you can change it.
More likely the actuating mechanism has gone 'over center'
You need to remove left footrest and left engine cover to check.
I'm with PJ on this one. If the worm gear is adjust out to far it will do exactly as you described. Loosen the nut on it and slowly turn it to the right and see if you here it "ping" back into place. Then adjust from there until it functions to your liking.
Ok, so i found out the the spring that normally pulls the cable back down popped off so I put it back on and then tried the clutch and it felt really soft and didnt seem to engage the clutch because I couldnt move through gears still. I did adjust the screw untill it "pinged" back to place like you said but its still soft and wont engage. So what Do I need to adjust to get it to engage better?
Thanks again everyone, Im hoping if i can get this done tonight I can ride the rest of the weekend.
-Ty
CB360ty said:
any ideas anyone?
Have you taken off the right side cover to see if your clutch plates are sticking together? FYI, you should drain the oil first to avoid a big mess.
I have not tried that yet but I don't know how that could be the problem because I never messed with that stuff. all I have done is messed with the clutch cable and that is when the problem started.
again any ideas would help me narrow this done. I will check the right side cover anyway though.
thanks
-Ty
It's just bad adjustment.
I had same problem for first time ever a couple of weeks ago (not one of my bikes)
If clutch cable is fitted properly, ball and ramp are correctly seated (probably not),loosen cable adjusters both ends, adjust screw on cover ('unscrew' to tighten mechanism onto pushrod)after it touches, back off 1/8 turn.
then adjust cable
You may need a couple of attempts before everything snaps into place.
PJ
then adjust cable
PJ
how can I tell when the push rod is on all the wat? and then once I back off an 1/8 all I should have to do is adjust the cable itself?
thanks again!
-Ty
after doing some researching online and through youtube videos, I think I figured out what you are talking about. I need to have a 1/8th inch play in the clutch lever...I think. I have yet to have a look at it since yesterday so I have a few things to try still.
Thanks everyone.
-ty
