Hey,
I recently have a 73 CB350 twin and am having so much fun with it I can hardly get any work done
I adjusted the clutch cable as described in the Clymer manual because it felt like it wasn't engaging. Even after that, I noticed that when I'm in first with the clutch in, the wheel turns (when the bike's on the stand), though I can with effort stop it with my right hand. When starting the bike, I need to be in first because if I'm in second, the bike lurches a bit even with the clutch engaged. That's the first problem.
So I thought, OK, I'll tighten the cable a little. So I tightened a little and then when I pulled the handle, something in the "connection box" (left side where the clutch cable enters the case) popped and the cable went slack. I thought "uh oh" thinking I'd brokenthe cable. So I undid the four screws to investigate. When the cover lossened up, the cable tightened back up and it's all good (as long as I loosen the cable back up). So I readjusted according to the manual.
Someone who has had this part of this bike opened recently may be able to picture what I'm describing here. If not, I'll post up pics later if I don't figure it out. I took the whole mechanism apart and I pretty much understand how it works. In a cylinder about an inch in diameter and 1.5 inches deep is a plate with indentations that ball bearings roll on. On top of that, there's another thin plate with three bearings in it. On top of that is a 3/4 inch thick metal plate with indentations. This top, thick plate appears to have wear on it where the ball bearings should settle into. It's possible that it is this part that needs replacing. However, I don't understand what is happening when this "pops". And I don't understand why the clutch would be always slightly not engaged. Nor in fact whether I should worry about it.
Any thoughts?
Any thoughts?
