clutch hard to pull
JRK5892
Over 1,000 Posts
on my TX500 yamaha... i just put the clutch cable back on, and adjusted it... MAN it is SUPER hard to pull in... i just removed the cable to lube that up to see if that may fix my issue... any other idea's out there... i know it is adjusted correctly...
any idea's... i am thinking it may be the clutch itself is not alighned correctly... or the worm gear (i hear about this but no clue what it is)
any tips would be great! before i go blind and start pulling stuff off when i should be putting it on!
I had a similar issue, after some troubling tho I realized it was because I was using the OEM cable which was way too long for use with clip-ons, i had it doing about 3 "S" turns which was causing it to bind up pretty bad...simple re-routing took care of it though...just a thought ..
I had the same issue with my throttle cable. Lubed the shit out of it and after a reroute it was smooth as butter.
ditto on that, routing seems to make the biggest difference in clutch cables... assuming they're in ok shape and all
awesome! i will re route everything out tomrrow and lube the hell out of it one more time! thanks fella's!
yep, lube the shit outta it. I had the same problem and kinda went overboard with the graphite stuff in a fit of rage, but it worked like a champ.
some Gell lube, re routed, adjusted it in again... smooth as glass! thanks guys awesome idea! hell i almost tore the clutch apart of that one.. thanks a ton!
