AzHonda
Coast to Coast
Having a hard time diagnosing what I did wrong. Here's the story.....
I split the cases on the engine to clean and paint the engine. Put it all back together and now the engine is in gear and will not shift out of it or into any other gears. The shifter moves up and down but no "clicking" into gear.
Questions....
Could I have put the cases back together wrong? I had all three fork guides facing straight down when i mated the cases. I dont thing that the guides could have been off and the case would have come together?
This may be the obvious answer and I will gladly wear the dunce cap if this is the easy fix. Does the clutch cable need to be hooked up? I only say this because on my CB360 I can go from first to neautral and back with out the clutch being pulled in. On this CL175, it will not do that.
And last, could I possibly have the linkage behind the clutch basket all wrong?
Thanks for any help.
Questions....
