Maritime
Over 10,000 Posts
Ok, I have been riding the bike sine I put the replacement motor in. It runs strong, when I first started riding I was getting clutch creep and adjusted the clucth till it stopped, drove for about 50 miles and then got clutch slip so re-adjusted again. The use motor was sitting for a while, about a year, so I expected that. Now I am adjusted to the point where the clutch just slightly creeps at idle in 1rst, the bike won't move with the brakes off and clutch pulled, but you can feel a slight grabbing. The problem I have is when I am riding and I give it throttle to acccelerate quick, the clutch slips, bike revs jump up quick but the bike doesn't move faster. When I am on the highway and I am going 60-70 miles an hour and want to pass or accelerate, twist the throttle and revs go up but bike doesn't want to go faster. Do I need a new clutch? Or can I adjust it? I am going to change the oil soon and will look at the plates and check for wear on them. Should I add a washer to the springs to get more force on them if the plates are within spec? Or should I just bite the bullet and spend the $80.00 I don't have on a new clutch/springs? I want to get the power to the road, the engine is working really well. Clymers is no help on this except for plate wear specs. and replacement instructions. I know the springs can get weak from heat/cold cycles.
Engine is a 82 CB450T, basically 450 nighthawk, CM450, SOHC honda twin with wet clutch
Thanks for any help/ suggestions.
Maritime
Maritime
