jimid
Active Member
Morning,
Having clutch issues on a 07 triumph 1050 w/ ~30k miles
Issue: clutch will not disengage. Power transmits through to rear wheel, regardless of level/cable. There is no force pulling the cable lever back.
Attempts: Adjusted cable, up and down. No results.
-pulled clutch cover off, cant see any issues inside. plates look clean. no build up or residue. plates do not stick.
-loosened clutch spring bolts to allow more travel. No results.
Any suggestions?
Added a video of the spring back. The cable is moved by my hand on the lever, and will not reset.
https://www.youtube.com/embed/TLlG1uv3Tx8
Any suggestions?
