woodardhsd
I've got a 78 CB400T, and I want to lower the front end slightly and stiffen up the front triples. The Cb400t's 78-80, and the cm400E used a weak stamped steel upper triple, but the CM400t, cm400c and 81-82 cb400t/cb450t/cm450t used a aluminum upper triple clamp.
The way the stamped triple is designed, you cant loosen the clamp bolts and slide the forks up a little like you can on the aluminum piece.
From some research, I've found all the cb/cm twins use the same steering bearings, but I think the stem lengths may be different, due to the difference in thickness between the upper triples. If teh stem lengths are the same, I could just pick up the aluminum upper triple and be good to go.
Would anyone with one of these bike's be willing to measure their stem length for me? That would be awesome. There's tons of them on ebay, but no one has posted measurements.
81 cb400t
82 cb450t
79-81 cm400t or cm400c
82-83 cm450c
Thanks,
Mike
81 cb400t
82 cb450t
82-83 cm450c
Thanks,
Mike
