CM450 Crank Case Vent Tube
Faoladh
I am working on a 1980 CM400a, replacing the engine with one from a 1982 CM450e. One of the things I am doing is replacing the big ugly filter box with pod filters and I am wondering what is normally done with the crank case vent tube that used to run to the filter box.
Thanks. I've seen a few pics now with a small cone filter added to the tube and pointed to the front and some with just a longer tube directed downward. Any advantages of one method over the other?
Short tube can pulse so suck dirt in, long tube doesn't have the same problem. You could still get bugs crawling in but the oil does put them off
I vented my cm450's case gases into my exhaust. It takes a small amount of drilling and welding but the results are worth it. I have attached an image of what I am talking about. There is a lot of info on how to do this on cars the principle is the same and you can buy a kit or just gather up the parts individually
You will also need a one way valve so the gases wont push back into your case.
